Common features |
Socket for LPCXpresso and mbed module |
50 pin expansion dual row pin list connector (male, 100mil pitch) for simple connection external designs and to a logic analyzer |
50 pin expansion dual row header connector (female, 100mil pitch) for simple connection to breadboard |
Battery powering (small coin battery) |
USB interface |
Reset pushbutton |
Digital IO |
RGB-LED (can be PWM controlled) |
5-key joystick switch |
2 pushbuttons, one for activating bootloader |
Rotary switch with quadrature encoding (timer capture) |
Temperature sensor with PWM output (timer capture) |
Analog IO |
Trimming potentiometer input (analog input) |
PWM to analog LP-filtering (PWM output and analog input) |
Speaker output (PWM output) |
Oscilloscope probe inout stage |
Serial bus - SPI |
Shift register driving 7-segment LED |
SD/MMC memory card interface |
Dataflash SPI-NOR flash |
Serial bus - I2C |
PCA9532 port expander connected to 16 LEDs |
8kbit E2PROM |
MMA7455L accelerometer with I2C interface |
Light sensor |
Serial bus - I2C/SPI shared |
SC16IS752 - I2C/SPI to 2xUART bridge; connected to RS232 full-modem interface and one expansion UART |
96x64 pixel white OLED (alternative I2C/SPI interface) |
Serial bus - UART |
USB-to-serial bridge, with automatic ISP activation |
RS422/485 interface |
Interface socket for XBee RF-module |
Specific LPC1768 (incl mbed) support |
CAN bus interface (can be simulated with LPCXpresso LPC1114/LPC1343) |
Ethernet RJ45 connector with integrated magnetic |
Dimensions |
150 x 180 mm |
Power |
Powered via USB (+5V) |
